Why quick translator separate multipolygon and area when translate data to shapefile?
  • March 29, 2016
  • 5 replies
  • 77 views
I’m using quick translator to translate date from oracle to shapefile and I got 2 shape files as results: one for multipolygon and the other for area..
When using Workbench everything is good. I got only one file.
Is there any parameters to change in the quick translator..
Thanks
erik_jan
Forum|alt.badge.img+26
  • March 29, 2016
I do not know why the default behavior of Quick translator is to separate polygons and multi-polygons.
An option is to create a workspace (FMW file) with FME Workbench in which you have just one Shape featuretype for areas and run that workspace using Quick translator.
  • March 29, 2016
Thanks.. Actually (I think) that should be corrected because it is difficult if every time I should make a workspace to do that..
erik_jan
  • March 29, 2016
I agree it should be corrected if this is the default behavior.
Please send a request to support@safe.com.
mark2atsafe
Forum|alt.badge.img+59
  • March 30, 2016
What does the logfile say for the Quick Translator? I see this at the foot of mine:
2016-03-30 11:57:14| 0.6| 0.0|INFORM|Emptying factory pipeline
2016-03-30 11:57:14| 0.6| 0.0|STATS |__CollectionTest(TestFactory): Tested 80 input feature(s) -- 0 feature(s) passed and 80 feature(s) failed
2016-03-30 11:57:14| 0.6| 0.0|STATS |__InstantiateAndHomogenizeCollections(DeaggregateFactory): Split 0 input feature(s) into 0 point-in-polygon feature(s), 0 donut polygon(s), 0 polygon(s), 0 line(s), 0 point(s), and 0 aggregate(s)
2016-03-30 11:57:14| 0.6| 0.0|STATS |__TidyOutput(TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
Just interested to know what it is doing.
  • March 31, 2016
the same as yours.
2016-03-31 09:48:01| 12.4| 3.5|INFORM|Emptying factory pipeline
2016-03-31 09:48:01| 12.4| 0.0|STATS |__CollectionTest(TestFactory): Tested 40 input feature(s) -- 0 feature(s) passed and 40 feature(s) failed
2016-03-31 09:48:01| 12.4| 0.0|STATS |__InstantiateAndHomogenizeCollections(DeaggregateFactory): Split 0 input feature(s) into 0 point-in-polygon feature(s), 0 donut polygon(s), 0 polygon(s), 0 line(s), 0 point(s), and 0 aggregate(s)
2016-03-31 09:48:01| 12.4| 0.0|STATS |__TidyOutput(TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
