The sliverremover transformer is configured with priority setting 0,1,2 for different areas. Idea was to keep area with the value 0 unchanged after running the workspace. But this is not the case. value 0 is also changed in some occasions. How can I be shure to keep the areas with this value untouched?
Why is the area with value 0 not preserved as is when using the sliverremover with priority 0,1,2?
