Why do I get 404 error when reading WMS?
  • Jun 13, 2023 11:19 AM UTC
  • 148 views
I have a WMS that I can open in e.g. QGIS. Both the FeatureReader and the OGC WMS reader can show me the different selectable layers in "Properties". But when I start the translation, I get a 404 error saying it cannot be found. This is the WMS I'm trying to read: https://geodata.naturvardsverket.se/planeringsunderlag_o_strategier/wms?layers=Sannolikt_och_potentiell_kontinuitetsskog
Why and what can I do about it?
itsmatt
Forum|alt.badge.img+48
  • Jun 13, 2023 12:23 PM UTC
Hmm indeed weird - I thiiiiink (not 100%) that their GetCapabilities is wrong. FME gets redirected to a different url which is defined in there as the GetMap request url. If you look in your FME log with just a basic reader you end up with a GetMap request URL which looks like:
http://geodata.naturvardsverket.se/arcgis/services/planeringsunderlag_o_strategier/MapServer/WmsServer?....
But the URL you've been provided is:
If you replace the URL back to the one you provided (in a browser) then you get a result:
imageMy guess is that the GetCapabilities document is wrong and needs to be fixed, but I'm not 100%. Likely QGIS is not using the URL provided in the GetCapabilites document but the one provided.
I suspect that the people who set up the service didn't spot the issue because it's an internal URL and it probably works for them.
I'm not sure if there is a workaround for this.
  • Jun 14, 2023 5:38 AM UTC
Thanks! That answer taught me a bit or two about WMS :) Hm, for now I might end up downloading their raster file instead then.
