Why are FeatureJoiner and FeatureMerger joining on UUIDs differently?
  • Apr 14, 2018 6:02 PM UTC
  • 101 views
residual
Forum|alt.badge.img+3
I have two uniqueidentifiers:
4F23402A-BBCD-498E-9136-C0C06F20AB57
4DE5DCD8-5D50-4272-B9DC-6D3997CC2F47
When both are set to UTF-8 encoding and run through a FeatureJoiner on Automatic comparison mode, they do not join - as they shouldn't.
However, when both UUIDs are set to UTF-16LE (which is how they appear in FME if they were read in from SQL Server) and run through a FeatureJoiner on Automatic comparison mode, they DO join. The same behavior occurs when set to Numeric mode. When set to String mode, obviously they do not join.
This behavior appears to be inconsistent with the FeatureMerger. With the FeatureMerger, these two UUIDs never join, regardless of comparison mode and UTF-8/UTF-16LE encoding.
So my questions: Is this the intended behavior of the FeatureJoiner? Why does FeatureJoiner's attempt to convert (UTF-16LE) UUIDs into a number appear to have a different result than when the FeatureMerger attempts to convert the same (UTF-16LE) UUIDs into a number? Perhaps I just don't understand the finer points of character encoding...
The attached workspace tests various combinations.
  • Apr 15, 2018 12:04 AM UTC
It seems to be a bug. I would recommend you to report it to Safe support.
fmelizard
Forum|alt.badge.img+22
  • Apr 15, 2018 12:06 AM UTC
Yep, its a bug alright. Already confirmed by development. We'll get it into a 2018.0 update as soon as we can. Sorry about this.
residual
  • Apr 15, 2018 12:27 AM UTC
Sounds good, thank you!
brianatsafe
Forum|alt.badge.img+13
Hi everyone! I am happy to report this has been fixed in the latest release of FME (https://www.safe.com/support/support-resources/fme-downloads/). The behavior of the FeatureJoiner is now consistent with the FeatureMerger.
