Why are feature attributes missing when using a reader?
  • Oct 24, 2018 3:51 PM UTC
  • 138 views
Why would feature attributes be missing when using a reader? On inspection features such as fme_basename or fme_dataset are present in table but with a value 'missing'??
Best answer by takashi
Most likely you have exposed them with the AttributeExposer. If so, try exposing them through the Format Attributes tab in the reader feature type, rather than using the AttributeExposer.
danilo_fme
Forum|alt.badge.img+58
  • Oct 24, 2018 3:57 PM UTC
Hi @cbrown
Could you share the print or the Workspace template?
Thanks,
Danilo
  • Oct 24, 2018 4:02 PM UTC
Do you have actual attributes in your input data called "fme_basename" and "fme_dataset"?
  • Oct 25, 2018 7:52 AM UTC
  • Oct 25, 2018 9:30 AM UTC
@takashi
Many thanks! That was the problem :-) They weren't checked to expose in the Feature Type Format Attributes. All good.
