which transformer would simply add a single line of text to line 1 of a text file?
  • January 23, 2017
  • 21 views
I have 100's of ASCII file containing coordinates which have no column names. I need to add "X Y Z" to the first line of every file. How could I do this with fme 2016?
  • January 23, 2017
One possible solution is to use a Text File reader and specify to read the whole file at once:
Before a Text File writer, insert an AttributeCreator (or something similar) that modifies text_line_data:
itay
Forum|alt.badge.img+18
  • January 23, 2017
Hi @robertdbuckley,
Another possible solution is the Column Aligned Text (CAT), where you can define the columns names in the reader parameters.
