?which tool can I use to add xdata in a *.dwg with autocad ?
  • Apr 16, 2018 2:41 PM UTC
  • 5 replies
  • 135 views
Hi
I would like to add different types of xdata for a layer from a .dwg with autocad.
lars_de_vries
Forum|alt.badge.img+10
I think this post should help you. It is a tutorial how to write to DWG including XData.
  • Apr 24, 2018 9:41 AM UTC
Thanks for your help !
I had see that post , it's not what I want.
I mean which tool can I use to add xdata work in autocad ,that without the FME.
oscard
Forum|alt.badge.img+23
  • Apr 24, 2018 10:06 AM UTC
I guess you will find better answers in an Autodesk community. I have created my own tools with .NET to accomplish that.
A quick Google search shows me this: https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoCAD-Core/files/GUID-F0299B36-232F-446E-9F81-98F300B36991-htm.html
oscard
jneujens
  • Apr 24, 2018 11:52 AM UTC
I have used FME at a customer before, in combination with .NET. Additional information on a certain autocad object coming from different databases was stored in the xdata using FME. But other parameters and values were created in .NET and stored in xdata as well. Like that, the xdata became concatenated string of key-value pairs.
