When to use Query based job transformation submitter Rest API ?
  • Sep 10, 2022 5:50 PM UTC
  • 28 views
raaaju1990
Forum|alt.badge.img+11
Hello,
I need more input/ information on what are all the scenarios I can use the below rest api call ?
POST /transformations/transactdata/< repository >/< workspace >
Also, the input here is a file and The 'application/octet-stream' type is used . So, may I know what type of input file should I use ? Will this API call convert my any input file into a streamed data and pass it to a workbench ?
Thanks.
  • Sep 12, 2022 7:15 AM UTC
I believe the description of the input file parameter is fairly helpful here:
The source dataset that the first reader will be initialized with. This can be any MIME type, except 'multipart' types, which are reserved for future use. The 'application/octet-stream' type is featured here to demonstrate the API call.
Also, note that this parameter is optional.
