What User Parameter format is needed so it can be used with a DuplicateFilter & AttributeKeeper as their 'Key Attributes' field input?
  • Feb 28, 2022 1:48 AM UTC
  • 70 views
anryan
Forum|alt.badge.img+8
I'm currently working in FME 2021.2 and trying implement a workbench that can do some dynamic filtering, etc by using a user parameter that defines which fields to act against. The workbench reads in zipped shp file(s) that can have different schemas each time it runs and I want to use a parameter to define which fields I wish to analyse. I can successfully get it to work when one field name is entered but never with 2 or more.
Does anybody know what the parameter type should be (eg. text) and what format the field names need to be entered as (eg. VM_STATUS,R20AH or VM_STATUS R20AH)?
When 2 or more fields, only 1 feature is returned. I know for a particular datasets that I should expect 207 which is what I get by manually selecting the fields when the data is cached while debugging the workbench.
Thankyou for any time spent looking at this
Best answer by kailinatsafe
Hello @anryan​, it would seem dynamic attributes aren't exactly handled well in the mentioned transformers (eg. AttributeKeeper). I tried a few different methods: concatenating desired values into a list, using the 'Attribute Name' user parameter (to select single or multiple attribute names), but I haven't had any good results. Unfortunately, I think python may be required for this.
There isn't really a way to make the Keeper/remover more dynamic, as you need to select which to keep/remove. However, there is an example by David Reksten, with Python on how to remove dynamic attributes here, perhaps you can take a look at the linked workspace there? Let me know if you have any further questions. Best, Kailin Opaleychuk
kailinatsafe
Forum|alt.badge.img+24
  • Mar 1, 2022 4:27 PM UTC
