What transformer should be used to remove m and z values in a shapefile using Fme?
  • Jul 23, 2018 2:33 PM UTC
  • 632 views
I know a way in arcmap using toolbox Conversion Tool under that i am using "feature class to geodatabase" to remove those values by unchecking the m and z values. But, for larger data set, arc map is crashing. Is their any transformer in FME, where we can remove those values in shape files?
Best answer by redgeographics
The 2DForcer removes z values, the MeasureRemover removes m values.
Forum|alt.badge.img+63
Thanks !! It worked..
