What to do with our model builder scripts?
  • Nov 8, 2017 7:37 AM UTC
  • 6 replies
  • 292 views
annette2
Forum|alt.badge.img+11
We are rebuilding our entire GIS analysis platform and are trying to map our exisiting processes to something better.
We receive ArcGIS model builder scripts from our Asset team that have no FME experience. Currently they are scheduled using Windows Task Scheduler. One suggestion in the team was to load these model builders as ArcGIS Server geoprocessing services and then use FME Server to call/schedule the geoprocessing service.
Can FME Server start an ArcGIS Server geoprocessing service?
Would it be better to export the model builder scripts to python and use the PythonCaller transformer within FME itself?
Is anyone using either of these methods?
gio
Forum|alt.badge.img+15
  • Nov 8, 2017 9:49 PM UTC
exporting them to python gives huge overhead, we had some laughs with that.
Reducing page-sized script to sometimes just a couple lines in python...
And you would still have to invoke their functions/factories. (or is that not an issue?)
Maybe parsing the python script to generate the fme script, then some manual post-labor?
Would require some work and experience
Manual conversion is the best, but also requires some work and experience.
Anyway at E sri they say their system has advantages..i see none though. Well, less memory intesive maybe. but then again creating lots of files to clean up after.
And of course model builder has improved quite a lot since i gave up on it...;)
Seldom use it though, sometimes to control mxd's.
ciarab
Forum|alt.badge.img+10
  • Feb 6, 2018 10:02 PM UTC
Hi @annette2
Did you ever progress this further, "Can FME Server start an ArcGIS Server geoprocessing service?"
Thinking about this also and wondering could I call a geoprocessing service from either desktop or server...
Thanks
Ciara
ciarab
  • Feb 7, 2018 12:38 PM UTC
Hi @annette2
Thanks
Ciara
Just tested it out and its quite easily achieved with HTTPCaller, I was able to set my parameters for the tool in the Query String Parameters.
Will be quite useful as allows us to automate the testing of the GeoProcessing Service as we run same tests across 3 environments, as well as load testing and then scheduling from FME Server
  • Feb 7, 2018 2:49 PM UTC
Here's one advantage I can think of: The ArcGIS toolboxes work with the tolerance and resolution set in the feature class/dataset, where as FME works in full precision. This can sometimes give some interesting differences when e.g. comparing geometries where rounding differences can throw off the results.
I hope/suspect this will be much improved with the new tolerance settings in FME 2018, however.
gio
  • Feb 7, 2018 4:51 PM UTC
Not sure if that is an advantage to Esri's model builder.
annette2
  • Feb 12, 2018 9:06 PM UTC
Hi Ciara, Good to hear from you and congratulations on your new job.
We have about 15-20 python scheduled batch jobs. Most we will port to FME.
The http will be an option for the jobs we cannot port to FME :)
