What is wrong with my OData reading?
  • Feb 12, 2019 10:47 PM UTC
  • 6 replies
  • 110 views
bruceharold
Forum|alt.badge.img+20
Hi all, I'm attempting to read this service:
https://data.wprdc.org/datastore/odata3.0/f2b8d575-e256-4718-94ad-1e12239ddb92
Attempting to supply a value for the Feed List parameter results in an error:
Python Exception <ValueError>: Unrecognized content typeapplication/atom+xml;type=feed;charset=utf-8
I'm using 2018.1.1.0 64 bit
Best answer by david_r
It seems like the server is returning a content-type header that the FME OData reader doesn't know how to handle:
Content-Type: application/atom+xml;type=feed;charset=utf-8
I recommend that you contact Safe support about this issue, including a link to this thread.
  • Feb 13, 2019 8:47 AM UTC
How are you connecting to the URL? We'll need some more details.
danilo_fme
Forum|alt.badge.img+58
  • Feb 13, 2019 10:34 AM UTC
Hi @bruceharold
I agree @david_r Is necessary to give us more details.
Are you trying to connect like Reader?
I tested here using the transformer HTTPCaller:
In the transformer HTTPCaller I maked the download xml format, you can check these configurations the image above.
Thanks,
Danilo
bruceharold
  • Feb 13, 2019 2:52 PM UTC
Sorry I didn't spell it out, I'm using the OData reader. I know I can call the URL as RSS or HTTP but the reader should work.
  • Feb 13, 2019 3:16 PM UTC
bruceharold
  • Feb 13, 2019 3:19 PM UTC
Thanks I contacted Safe.
trentatsafe
Forum|alt.badge.img+7
Hello @bruceharold
I have filed an issue to track this behavior. I have also linked the posting to the internal Issue. I will post any updates as they become available!
