What is the way to submit transform to FMEStore?
  • February 17, 2015
  • 46 views
Over the years, I have created a couple of custom transformers that may be usefull to others that I'd like to share.
Anybody know the procedure to submit a transformer to FMEStore? Is there some limitations, for instance, does transformers using python libraries not installed by default with FME are accepted?
Thank you for your advices,
Maxime Demers
Best answer by takashi
Hi Maxime,
You need a contract with Safe to publish your transformers in the FME Store.
Contact Safe directly to get detailed information.
Takashi
  • February 17, 2015
Hi Maxime,
Takashi
  • February 17, 2015
send a mail to Safe support, they will send you the terms and conditions for publishing there, as well as a sign-up form.
David
  • February 17, 2015
"contract" may not be a suitable word. I intended to say "agreement".
Anyway, contacting Safe is the fastest way.
Good luck!
