I believe the most required transformer will be the AttributeManager for renaming, concatenating and creating attributes.
As CSV does not allow geometries the CoordinateConcatenator will also be useful.
But so many more options are available, depending on your data.
Thank you, will give the AttributeManager and the CoordinateConcatenator a try.
