What is python 'CROSS' function equivalent expression in FME ?
vimva679
Forum|alt.badge.img+9
Python = np.cross(XYZ, ABC) ????
Best answer by geomancer
It's all just a bit of math.
CrossProd_X = @Evaluate(@Value(Y)*@Value(C)-@Value(Z)*@Value(B))
CrossProd_Y = @Evaluate(@Value(Z)*@Value(A)-@Value(X)*@Value(C))
CrossProd_Z = @Evaluate(@Value(X)*@Value(B)-@Value(Y)*@Value(A))
paalpedersen
Forum|alt.badge.img+7
  • December 6, 2023
Use the pythoncaller. If you need further guideance you must provide som example data.
paalpedersen
  • December 6, 2023
import fmeobjects
import numpy as np
class FeatureProcessor:
  def __init__(self):
    pass
  def input(self, feature):
    a = feature.getAttribute('_list{}.a')
    b = feature.getAttribute('_list{}.b')
    r = np.cross(a, b)
    for i, v in enumerate(r):
      feature.setAttribute(f'_list{{{i}}}.result', v)
    self.pyoutput(feature)
  def close(self):
    pass
vimva679
  • December 6, 2023
paalpedersen wrote:
import fmeobjects
import numpy as np
  def __init__(self):
    pass
    r = np.cross(a, b)
  def close(self):
    pass
Based on L and F and UVN
I would like to assign DX, DY and DZ values to DU, DV and DN
def myfinction(L, F, Dxyz):
   DLF = [0,0,-1]
   ULF = [0,0,1]
   NLF = [0,1,0]
   SLF = [0,-1,0]
   ELF = [1 ,0,0]
   WLF = [-1 ,0,0]
   if L == "D":
      UAP = DLF
   elif L == "U":
        UAP = ULF
   elif L == "N":
       UAP = NLF
   elif L == "S":
       UAP = SLF
   elif L == "E":
       UAP = ELF
   elif L == "W":
       UAP = WLF
   if F == "D":
      FAP = DLF
   elif F == "U":
        FAP = ULF
   elif F == "N":
       FAP = NLF
   elif F == "S":
       FAP = SLF
   elif F == "E":
       FAP = ELF
   elif F == "W":
       FAP = WLF
   # STEP 3 a
   # Cross produ²ct
   VAP = np.cross(FAP, UAP)
   DU,DV,DN = np.linalg.inv(np.column_stack((UAP, VAP, FAP))).dot(np.array(Dxyz))
   return DU,DV,DN
vimva679
  • December 6, 2023
paalpedersen wrote:
import fmeobjects
import numpy as np
  def __init__(self):
    pass
    r = np.cross(a, b)
  def close(self):
    pass
The empty BLACK cells should have the values as Target
paalpedersen
  • December 6, 2023
paalpedersen wrote:
import fmeobjects
import numpy as np
  def __init__(self):
    pass
    r = np.cross(a, b)
  def close(self):
    pass
vimva679
  • December 6, 2023
paalpedersen wrote:
import fmeobjects
import numpy as np
  def __init__(self):
    pass
    r = np.cross(a, b)
  def close(self):
    pass
Noooo, this target column is just to give idea how at the end excel sheet should look ........i.e. what are the values expected in that empty BLACK header Cell (D:U , D:V and D:N)
this is how the excel sheet looks like
the values are dependent on
DLF = [0,0,-1]....down
ULF = [0,0,1]....up
NLF = [0,1,0]...North
SLF = [0,-1,0].....South
ELF = [1 ,0,0]..... East
WLF = [-1 ,0,0].....West
vimva679
  • December 6, 2023
paalpedersen wrote:
import fmeobjects
import numpy as np
  def __init__(self):
    pass
    r = np.cross(a, b)
  def close(self):
    pass
if you cld also share me your FME workbench that wld be ease as well
geomancer
Forum|alt.badge.img+50
  • December 6, 2023
paalpedersen
  • December 6, 2023
paalpedersen wrote:
import fmeobjects
import numpy as np
  def __init__(self):
    pass
    r = np.cross(a, b)
  def close(self):
    pass
Its just a boilerplate for you to work with. You can setup your if else statements, and all that stuff. This is just to show how to get started.
paalpedersen
  • December 6, 2023
paalpedersen wrote:
import fmeobjects
import numpy as np
  def __init__(self):
    pass
    r = np.cross(a, b)
  def close(self):
    pass
Everything in the workspace is evidently present in the image.
vimva679
  • December 6, 2023
paalpedersen wrote:
import fmeobjects
import numpy as np
  def __init__(self):
    pass
    r = np.cross(a, b)
  def close(self):
    pass
alright let me get started and see if my workbench is able to get it right inserted .
vimva679
  • December 6, 2023
paalpedersen wrote:
import fmeobjects
import numpy as np
  def __init__(self):
    pass
    r = np.cross(a, b)
  def close(self):
    pass
this is the error image
