What I am doing wrong? Bufferer tool error
  • Apr 8, 2016 8:21 PM UTC
  • 183 views
Hello people,
I am new to GIS and FME. For my study we are using ArcMap. Ik have an shapefile and now I need to create a 5000 meter buffer around the shapefile. Therefore I must use the Bufferertool from FME. The result wil be written to a file geodatabase.
Anytime I run the spatial ETL tool from FME I get an error and see no buffer of 5000m around the points of the shapefile.
I have ad some screenshot. Does anybody know what I am doing wrong in my setup?
Thanks in advance.
Tijs
Best answer by erik_jan
The coordinate system of your source data is in lat / long (degrees).
The Bufferer will use the same units as your data, so you create a buffer of 5000 degrees, which is way out of the galaxy.
You need to use the GeographicBufferer or need to reproject (Reprojector) your data before creating the buffer.
erik_jan
Forum|alt.badge.img+26
  • Apr 8, 2016 8:38 PM UTC
mark2atsafe
Forum|alt.badge.img+59
Also, click on the cogwheel button on the right-hand object (we'd call it a Writer Feature Type) and check the parameters to ensure it is set to a polygon geometry.
If you translate from a points dataset then, by default, the output will expect points. If you change them to polygons with the Bufferer then the data will probably be thrown away when FME tries to write it. So make sure the output is set to write a polygon geometry.
  • Apr 11, 2016 7:20 AM UTC
Hello people,
It works! Thank you very much al for your advice!
  • Sep 24, 2018 2:16 PM UTC
Hello people,
Hi
Please show me how it , in answering your question?
a workflow diagram would go a long way.
