What are the different encoding profiles for the JPEG2000 writer?
  • Jan 30, 2019 4:13 PM UTC
  • 170 views
koenvdw
Forum|alt.badge.img+7
Can somebody explain met the different encoding options for JPEG2000?
Normally we convert our TIFFS to ECW with a nice result and the converting is very fast.
Arcmap server needs an additional license to use ECW's, so I was thinking to use JPEG2000 instead.
The image quality is a tiny bit better and the file size is smaller, but the convertion took so long...
I used the standard FME writer options. Encoding profile 1 that is.
What is the difference between all those profiles? There is very little documentation about it or I cant find any.
Thx
Koen
daveatsafe
Forum|alt.badge.img+24
  • Jan 30, 2019 10:48 PM UTC
Hi @koenvdw,
You can find the FME documentation on the JPEG 2000 profiles midway down the page at https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/jpeg2000/jpeg2000_format_attr.htm
Profile 0 uses a limited number of JPEG 2000 features. Profile 1 uses a few more, but not the complete set. Profile 2 uses the complete set. Profile 0 gives you the best compatibility with applications that have not implemented the complete JPEG 2000 feature set.
The NPJE and EPJE protocols were designed for military applications, and would normally be specified in the data delivery requirements.
koenvdw
  • Feb 1, 2019 11:12 AM UTC
Ok thx for the explanation.
I did a test and converted the same TIF with different settings.
Here are the results:
TIF -> ECW 26min41 1.76GB
TIF-> JPEG2000 (prof 0 and 2) 28min37 1.31GB
TIF-> JPEG2000 (NPJE) 24min51 1.29GB
TIF-> JPEG2000 (EPJE) 18min56 1.29GB
They all take the same time to load in QGIS after panning (or the difference isn't noticable).
There is no difference in quality between the JPEG2000's.
The JPEG2000's was a tiny bit better than the ECW (more contrast, but negligible ).
So for me the convertion time is the most important. I'll stick to JPEG2000 EPJE.
