What am I doing wrong with the XSD driven XML writer. The resulting XML is empty.
  • Feb 27, 2023 9:58 AM UTC
  • 89 views
hasant1973
Forum|alt.badge.img+3
Hi, I'm trying to understand XSD Driven XML Writer and wrote a simple example that reads 3 CSV file with customer and address data and write a xml file containing all of the feature types.
The resulting xml is empty when I run the whole process. Running "customers" only writes at least the top element into the xml.
I connected all feature types with xml_parent_id and xml_id together.
Unfortunately the error message is saying nothing that would help me to find my problem.
Please help me with providing a information or repairing my work sheet.
I could also not find any example for this problem.
Best answer by markatsafe
@hasant1973​ Thanks for including a sample dataset and workspace. You're very close.
The xml_id must be unique for the entire dataset. FME will use those to make the associations between the objects. If you already have an id (custid) then you can use a prefix to make it unique - i.e.
customer-@Value(custid)
The deepest nested object (address) doesn't need an xml_id as nothing points back to it.
I've attached a slightly revised workspace (FME 2022.2)
  • Feb 27, 2023 11:30 PM UTC
hasant1973
  • Feb 28, 2023 12:58 PM UTC
Oh, I completely miss understood the documentation. It works now. Thanks a lot.
