Want to generate output for multiple line features shapefiles with Select by location method to get exact overlap and with some distance linear feature with no overlaps.
  • Aug 10, 2021 4:26 AM UTC
  • 99 views
actualabhijeet
Q1Q2Please refer this above two snapshots for better understanding.
Hello,
I have 20 shapefiles with no unique attributes in them.This all shapefiles are Line features. I want to generate the output with ovelapping part with exact overlap, and lines which are not overlapping but are parallel to each other at 3 meters distance.
for example see below image output seen and generated in ArcGIS for 2 shapefiles.
Need to generate same result for 20 shapefile in FME. Need help or solution for this problem.
itsmatt
Forum|alt.badge.img+48
  • Aug 10, 2021 7:14 AM UTC
For the exact match you should be able to use the LineOnLineOverlayer, for parallel lines you could take a look at the FuzzyParallelLineFinder (Custom Transformer). Also the image didn't get uploaded with your post.
actualabhijeet
I have uploaded the image now you can check and provide your feedback with solution.
itsmatt
  • Aug 10, 2021 1:24 PM UTC
Yeah, I think your best approach would be with a combination of the LineOnLineOverlyer and the FuzzyParallelLineFinder. It's a tricky problem for sure. Cleaning geometries like this is hard.
@actualabhijeet​ You might also try the Matcher using the Frechet distance
