Want to execute the transformers in order FME workspace
  • Dec 18, 2025 5:19 AM UTC
  • 104 views
sudhakary
Forum|alt.badge.img+3
!--startfragment>
I want to find the deltas from A(users are editing) & B(for analysis) environments and want to update the deltas in B environment on daily basis. My workspace created as below
ESRI feature class from A as rader and same feature class from B as readers, then
NoFeaturesTester - If the database disconnected or any reason to unable to read the sources, it will terminate the process through "NoInput" port from both A & B readers, then
ChangeDetector - This will finds the DELTAS from A & B and will update B feature class based on GLOBALID
Configured 22 feature classes as above in one workspace.
Want to execute this process one after feature class after one feature class, like
FeatureClass1 -- Reader A > Reder B > NoFeaturesTester A >  NoFeaturesTester B > ChangeDetector > Writer, then
FeatureClass2 -- Reader A > Reder B > NoFeaturesTester A >  NoFeaturesTester B > ChangeDetector > Writer, then
FeatureClass3 -- Reader A > Reder B > NoFeaturesTester A >  NoFeaturesTester B > ChangeDetector > Writer, then
FeatureClass22 -- Reader A > Reder B > NoFeaturesTester A >  NoFeaturesTester B > ChangeDetector > Writer
!--endfragment>
j.botterill
Forum|alt.badge.img+69
  • Dec 18, 2025 9:24 AM UTC
Expose the format attribute fme feature type. You could bring all connections into a junction or the FeatureTypeFilter transformer. You this to sort the ports or utilising an AttributeValueMapper to assign a new field with a number, then place a sorter with FME Feature Type. Then use another FeatureTypeFitler or AttributeFilter to pass each into Writer feature types
