Want to convert 3 character month to 2 digit month
  • Jan 8, 2019 6:30 PM UTC
  • 8 replies
  • 192 views
aaron
Forum|alt.badge.img+12
I am trying to convert a three character month to a two digit month (e.g. - Mar to 03) using FME 2016.1 (build 16492). Should be easy enough using the DateFormatter but the converted value returned is always 01. I think my parameters are set up correctly. Screenshot attached. Any ideas?
Thanks,
Aaron
Best answer by ebygomm
I think the DateFormatter in 2016 only works on dates, so you can convert 01-Jan-2018 to 01-01-2018 but not just the Jan element on it's own.
There are a number of other ways to convert the months to their numeric values if it's just months with no day and year, e.g. attributevaluemapper
Or appending next in front of your 3 letter month and putting that through the date formatter using auto as the source will work too
chrisatsafe
Hi @aaron,
Not sure why the DateFormatter isn't giving you the correct output but it works with the DateConverter using the following parameters:
Input
Output
Here is a sample workspace: 2016.1_DateConverter.fmwt
Forum|alt.badge.img+54
  • Jan 8, 2019 7:25 PM UTC
aaron
  • Jan 8, 2019 8:51 PM UTC
Thanks @egomm and @ChrisAtSafe, both of your solutions work. I appreciate it!
Aaron
  • Jan 9, 2019 9:30 AM UTC
Hi @aaron,
Input
Output
FYI, the images are broken...
  • Jan 9, 2019 9:31 AM UTC
An alternative solution would be to use the AttributeValueMapper.
jkr_wrk
Forum|alt.badge.img+37
  • Jan 9, 2019 9:48 AM UTC
This would be my choice for this kind of problem. But the DateConverter could be more robust because it can deal with oct,Oct,10,okt differentiations.
  • Jan 9, 2019 11:36 AM UTC
Yes, it would absolutely depend on the input data.
chrisatsafe
TY, re-uploaded the attachments.
