visualize if there are more than one point in a polygon (a lot off points and polygons)
  • Aug 16, 2018 2:15 PM UTC
  • 75 views
jopie
Participant
Forum|alt.badge.img+3
The question is:
Which areas have more than two points in it.
So I want to make a selection of points in a lot of area..
Visualize if there are more than one point in a polygon (a lot off points and polygons)
Forum|alt.badge.img+54
  • Aug 16, 2018 2:26 PM UTC
You can use a spatial relator or a point on area overlayer to count the number of points falling within a polygon
danilo_fme
Forum|alt.badge.img+58
  • Aug 16, 2018 2:29 PM UTC
Hi @jopie
I believe that you can use the transformer PointOnAreaOverlayer to generate the attribute _overlaps.
After, I uggest you to use the transformer Tester and configure this: _overlaps > 2 ( for example )
Thanks,
Danilo
