Vertical Lookup
  • Jul 4, 2019 7:22 AM UTC
  • 5 replies
  • 95 views
checcosisani
Forum|alt.badge.img+14
Hi
I need to find and extract from column B the value present in column A
for first record for ex PACHINO
any suggestion ?
Thx
Francesco
Best answer by ebygomm
I would use a StringReplacer
Forum|alt.badge.img+54
  • Jul 4, 2019 7:26 AM UTC
By extract, do you mean remove the value from column B that is in column A?
So the value remaining in column B would be SP PER ISPICA PACHINO 96018 ? Or do you want to remove both instances?
checcosisani
  • Jul 4, 2019 7:29 AM UTC
Yes if possible remove both instances and if possible insert a comma (useful for split string )
thx
  • Jul 4, 2019 7:35 AM UTC
checcosisani
  • Jul 4, 2019 7:42 AM UTC
.... thx very simple
I had tried complicate solutions ....
thx
Francesco
checcosisani
  • Jul 5, 2019 9:44 AM UTC
Hi
small update
If the text to replace i stored in an external table how can manage the replacement ?
Francesco
