Version 5 UUID
  • Aug 19, 2025 10:12 PM UTC
  • 5 replies
  • 189 views
mnash
Hi all,
I’m new to FME and would like to know if there is a way to generate a v5 UUID in FME 2024? From what I have read I can’t see a method for this.
Thanks.
Best answer by hkingsbury
You could make use of a python caller and uuid.uuid5()
https://docs.python.org/3/library/uuid.html#uuid.uuid5
crutledge
Forum|alt.badge.img+55
  • Aug 19, 2025 10:22 PM UTC
https://support.safe.com/hc/en-us/articles/25407440578189-Creating-a-Unique-Identifier-CRCCalculator
I don’t know about official v5 but this should give you something similar. Do you think this would work?
mnash
  • Aug 19, 2025 10:25 PM UTC
Thanks for the reply. I looked at CRC but I need the value to be in UUID format to satisfy downstream requirements.
hkingsbury
Forum|alt.badge.img+73
  • Aug 20, 2025 1:07 AM UTC
mnash
  • Aug 20, 2025 1:12 AM UTC
Thanks, that’s what I have ended up using and it’s working as required.
alexbiz
Forum|alt.badge.img+35
  • Aug 21, 2025 8:33 AM UTC
I was curious, so I’ve made a CT for that (but on FME 2025 tho 😅)
https://hub.safe.com/publishers/abizien/transformers/uuidv5generator
