Validating AutoCAD version
  • Jul 10, 2017 4:17 AM UTC
  • 7 replies
  • 142 views
chriswilson
Forum|alt.badge.img+29
I have seen that the version of AutoCAD a dwg file was saved in can be found as per this link, however I'm after ideas for a good, quick way to validate this - e.g. version must be 2007 or newer. I am using the RealDWG reader, and the workspace will have to work on FME Server.
I have tried exposing the autocad_version format attribute, but in the file I am testing no value comes through for this. I do note that FME was able to do a version check when reading as shown in the log, in which case this file was found to be AutoCAD 2007.
I have thought to perhaps save the file to a temp location, read it back in with a text reader and find the version through that but I'm hopeful of a slightly tidier solution within the workspace.
Also been asked to validate dimension type, but again autocad_dimension_type is missing. Perhaps it's just my source data letting me down!
Best answer by danilo_fme
Hi @chrisw84,
I tested the extract the attribute :autocad_version with succefull.
When i put the Reader RealDWG , Parameters -> Advanced -> Read Drawing Entity Graphics will be enable:
And expose the attribute autocad_version. After run the Workspace the result will show in the level 0.
Thanks in Advance,
Danilo
stalknecht
Forum|alt.badge.img+22
  • Jul 12, 2017 3:39 PM UTC
Can you share a sample?
danilo_fme
Forum|alt.badge.img+58
  • Jul 12, 2017 5:12 PM UTC
Hi @chrisw84,
Thanks in Advance,
Danilo
chriswilson
  • Jul 12, 2017 9:21 PM UTC
Hi @chrisw84,
Thanks in Advance,
Danilo
Thanks Danillo, I'll take a look at that.
chriswilson
  • Jul 12, 2017 9:22 PM UTC
Unfortunately not, this is sensitive data that I can't share. I am going to look at Danilo's solution below.
danilo_fme
  • Jul 13, 2017 12:57 PM UTC
Hi @chrisw84, perfect :)
chriswilson
  • Jul 13, 2017 11:54 PM UTC
Yep, that works - fantastic, thanks Danilo!
danilo_fme
  • Jul 14, 2017 1:47 PM UTC
Hi @chrisw84, i'm happy that your issue was resolved :)
