Validate URL from Excel
  • December 16, 2021
  • 162 views
hugues
Hi. I have a xlsx file with a field containt Path to a PDF. I want to validate if the PDF of the path exist. Can you help me. Thank you.
hkingsbury
Forum|alt.badge.img+55
  • December 16, 2021
hugues
  • December 17, 2021
I can't run the transfomer ? it's all stay gray...
drc43
Forum|alt.badge.img+11
  • December 17, 2021
What version of FME are you using? The Hub page says it requires FME 2020.0.2.1 (Build 20238) or higher.
caracadrian
Forum|alt.badge.img+23
  • December 17, 2021
I have posted a FME transformers only solution to your other thread: Compare a XSLX field with folder with PDF (safe.com)
