UTM to Lat/long
  • August 18, 2016
  • 5 replies
  • 272 views
I have a CSV with XY data for Kansas City. I've been told its in UTM. Not sure of the zone though (zone 15?). How do I convert this to Long and Lat?
  • August 18, 2016
Take a look at the CsmapAttributeReprojector.
You can visually verify the UTM zone by using a VertexCreator and a CoordinateSystemSetter before sending it to the Inspector with a background map.
Awesome! I'll give that a try. Thanks
erik_jan
Forum|alt.badge.img+26
  • August 18, 2016
You can even read the CSV file without using the VertexCreator. Set the coordinate system in the reader and set the attribute datatype to be x-coordinate and y-coordinate. The reader will create the geometry points automatically in the chosen coordinate system. Add an inspector to view in the Data Inspector. Then insert a Reprojector before the inspector to re-project to Lat/Long and view again.
itay
Forum|alt.badge.img+18
  • August 18, 2016
or... Read the csv as a non spatial features and use the attribute reprojector to convert to lat long
  • August 19, 2016
Which is exactly what the CsmapAttributeReprojector does :-)
