I'm using the RasterBandMinMaxExtractor to pull the min and max values before going into a RasterExpressionEvaluator. I have right clicked on the RasterBandMinMaxExtractor and exposed elements for _band{0}.min and _band{0}.max but when I use this expression it fails to create an output:
(((A[0]-@Value(A:_band{0}.min)))/(@Value(A:_band{0}.max)-@Value(A:_band{0}.min)))
Is there something wrong with my expression?
Thank you!
