Using the ProcessID and TimeStamp as my log name - failing on rename with py3.x but not 2.7
  • Jan 14, 2020 10:18 PM UTC
  • 116 views
salvaleonrp
Forum|alt.badge.img+23
Using the logic from this post and this post, I wanted to rename my log file using the Pyhton shutdown script.
For some reason, os.rename works only with python 2.7 and not python 3.x.
I tried single, double, and triple quotes; used raw, and I can't seem to find a good way to correct os.rename. Used FME_macro and just a string for the source file. Nothing worked so far.
# Import modules
import fme, datetime, time, os
# Get current date and time
dateToday = datetime.date.today().strftime('%Y/%m/%d')
timeNow = datetime.datetime.now().time().strftime('%H.%M.%S')
logger = open(FME_LogFileName,'a')
logger.write('Date: {}\n'.format(dateToday))
logger.write('Time: {}\n'.format(timeNow))
logger.write('ProcessID: {}\n'.format(fme.processID))
logger.write('Status: {}\n'.format(fme.status))
logger.write('Workspace duration was {} seconds\n'.format(fme.elapsedRunTime))
logger.write('Total feature read {}\n'.format(fme.totalFeaturesRead))
logger.write('Total features written {}\n'.format(fme.totalFeaturesWritten))
src = str(FME_LogFileName)
dirpath = FME_MacroValues['FME_MF_DIR'] # directory path
if dirpath.endswith('/'):
dirpath = dirpath[:-1]
timestamp = time.strftime('%Y%m%d%H%M%S')
id = str(fme.processID)
logname = dirpath + '\\' + id + '_' + timestamp + '.log'
print('Source: ' + src)
print('Destination: ' + logname)
#os.rename(src,logname)
print ('Renaming logfile... ' + logname)
Result when I rem os.rename line
My version of the workspace attached
Best answer by takashi
Hi @salvaleonrp, I'm afraid that the script fails to run even if using Python 2.7 interpreter, because the opened file (the  "logger" object) has not been closed before renaming that.
I think the script could be run successfully if you closed the file after writing additional information.
logger.close()
Alternatively you can use the with statement here. In the with statement, the opened file would be closed automatically without using the close method. I would recommend you to use the with statement usually to open/close a file.
with open(FME_LogFileName,'a') as logger:
See here to learn more about the with statement: https://docs.python.org/3.7/reference/compound_stmts.html#the-with-statement
  • Jan 14, 2020 11:16 PM UTC
logger.close()
salvaleonrp
  • Jan 14, 2020 11:40 PM UTC
Thanks for the tip @takashi and the python notes. It gets weirder as it worked for me with or without the logger.close statement on 2.7 - see screenshot below. I'll try your suggestion using the with statement.
salvaleonrp
  • Jan 14, 2020 11:49 PM UTC
logger.close()
After using with statement my shutdown script works. Thanks again!
