Using system caller to change a folder name
  • Jun 17, 2020 4:29 PM UTC
  • 104 views
mackenziebudda
Participant
Forum|alt.badge.img+5
I'm trying to change the name of a folder when running a workspace. I would like it to update the folder name from [job name_YYYYMMDD] to put in the date of when the workspace is run.
I tried using system caller however it doesn't seem to work: below is a screenshot of my command line:
I know @DateTimeNow() doesn't have the date format I'm looking for, does anybody know how I can update that as well?
Forum|alt.badge.img+54
  • Jun 17, 2020 5:37 PM UTC
To get the correct date format you can use
"@DateTimeFormat(@DateTimeNow(),%Y%m%d)"
I'm not sure why you statement isn't working otherwise, I take it the Job Folder parameter is the full path?
  • Jun 18, 2020 6:51 AM UTC
As mentioned by @ebygomm, verify that the parameter "Job_folder" contains a full path.
If that does not work, please post the relevant log messages here.
