Using SchemaMapper to Map Data into an Existing Schema
  • Nov 23, 2012 4:45 PM UTC
  • 6 replies
  • 249 views
fmelizard
Forum|alt.badge.img+22
I'm able to figure out how to map a single feature coming from one schema to an existing feature of another schema using the Schema Mapper tranformer.  The problem that I'm having is how to map the rest of the features using the same SchemaMapper transformer without having to create one for each feature that are within the two schemas. Here is schematic of what i'm trying to do.  Note that the Out feature already exist in the output schema.
RoadL  ------------------------>  |                                |-------------------------> RoadL_Out
RiverL --------------------------> | SchemaMapper  |-------------------------> RiverL_Out
SandA  ------------------------>  |                                |------------------------->  SandL_Out
What's happening for me is that the total number of features from the incoming schema are being inserted into each of the output features.  That is, if the total number of the road (200), river (700) and sand (100) feature is 1000, then the transformer tries to write 1000 roads, 1000 rivers and 1000 sand features.
Many thanks,
Sam
sigtill
Forum|alt.badge.img+25
  • Nov 23, 2012 5:03 PM UTC
And you have looked into the examples at: http://evangelism.safe.com/fmeevangelist41/ and also followed the two links at the bottom?
It seems you havent specified Feature-mapping, only attribute-mapping. But it is difficult to see unless you attach your SchemaMapper and Mapping-file
fmelizard
  • Nov 23, 2012 5:54 PM UTC
Thanks Sig,
Having you point me to a few otherbexamples that I hadn't seen yet, I noticed that although I had included the feature mapping (that you were inquiring about) I did not have the feature filter after my SchemaMapper transformer. Once I included the feature filter, it all worked.
Since I have your undevided  attention, would you happen to know how to handle/map NULL attribute values?  For example, how would I set up the spreadsheet that the SchemaMapper points to the mapping of a NULL attribute value for HYC to a value of 1 for the outgoing HYC_OUT attribute?
Again many thanks for your quick response.
Sam
sigtill
  • Nov 23, 2012 8:36 PM UTC
In general Schemamapping is one of the difficult things, but also most usefull in FME! So practicing it alot is well worth it!
So you want something like this?:
InputFeature:
Attribute: HYC = NULL
OutputFeature:
Attribute: HYC_OUT = 1 (if HYC = NULL in input)
If you always want to add a Default Value (when no value is present) you can add a colum.
More information is here (if you havent read already), just search for "default value" and it should give you additional info : http://evangelism.safe.com/fmeevangelist46/
fmelizard
  • Nov 24, 2012 9:12 PM UTC
Hi Sig,
Here is an extra of my mapping spreadsheet.
Source_Attribute    Source_Value    Target_Attribute   Target_Value
TUC                                  4                          TYP                 3
TUC                                  2                           TYP               41
TUC                                 NOT  IN (4,2)         TYP                -999999
                                        OR  IN (0,3)
                                        OR  IS NULL
From my few tests, I found that the transformer accepts the values referenced in the NOT IN operator, but ignores everything after.
Thanks again,
Sam
  • Nov 25, 2012 2:42 AM UTC
Re: "how to handle/map NULL attribute values?"
You could place an "NullAttributeReplacer" transformer ahead of the schema-mapper, and set the null values to something that you know would never appear in your data, like "__Null__" or somthing like that. Then enter that value in your schema-mapper file with the resulting mapped value that you would like it to place instead. I could send you an example if you still need more details.
fmelizard
  • Nov 25, 2012 3:47 AM UTC
Thanks Vic, no need to send an example yet. I think I can figure it out from what you told me.
Cheers,
Sam
