I am a very new user to SAFE FME and I am still learning the tool. What I am trying to figure out is how to publish a .hyper data source file to our on-prem tableau server. I am using the 2020.1 version of safe fme with the new .hyper writer. My basic question is how do you do this. More specifically what I need help understanding is: (1) how to write the XML into Safe FME to do this per tableau (see this document: https://help.tableau.com/current/api/rest_api/en-us/REST/rest_api_ref_publishing.htm); (2) can I do this without having to save a .hyper file locally; (3) can I create a macro to make this easier for others and adjust the settings (like append the data, replace the data, etc.).
Thanks in advance, Greg.
Be the first to reply!
