Using Regex within AttributeValidator to match anything but X string
  • Aug 7, 2018 2:45 PM UTC
  • 364 views
I am sure this is a simple fix for this, but I've been testing this for hours now and going nowhere!
In AttributeValidator, I want to FAIL an attribute which contains a certain string. The most logical thing I could think of is to use the Contains Regex validation rule. Let's say I want to 'Fail' every attribute where it contains a string which = FME. I have trawled the internet and got the following expression to work within the Regex Editor:
\\b(?!FME)\\b\\S+
However, when it runs in the AttributeValidator, attributes which i have engineered to contain FME, appears from the Passed output port.
1. Is there a much simpler way within the AttributeValidator to fail any attribute which contains a certain string, rather than regex?
2. If not, am I doing something fundamentally wrong with the Regex or validation rule?
Thanks
Forum|alt.badge.img+54
  • Aug 7, 2018 2:51 PM UTC
[^fme] should work for everything except fme
Edit: although it doesn't appear to....
  • Aug 7, 2018 3:08 PM UTC
Thanks, @egomm that works! However, what I should have put in the question above was that there could be other string in the attribute, e.g, MEF and [^fme] would include this as well. What i need is a string only match and it looks like that is a character match?
  • Aug 7, 2018 3:29 PM UTC
Try ^(?!.*fme).*$
  • Aug 7, 2018 9:34 PM UTC
Additionally, if word boundaries are required before and after 'FME', try this one.
^(?!.*\bFME\b).*$
