Using multiple SQL queries in Inline Querier
  • August 15, 2017
  • 149 views
I have two datasets:
1) DBF1 - It contains demand and patterns corresponding to a particular ID
2) DBF2 - It contains the factor corresponding to each PATTERN
I need to create a new column for each type and add the factor corresponding to PATTERN_ID, otherwise the default factor is 0.
The output result result would look as follows:
I tried using Feature Merger, but I felt that it would require multiple Feature Mergers to achieve the same.
I even tried Inline Querier but it does not permit more than one SQL statements.
Is there an alternative of doing the same
Best answer by erik_jan
The InlineQuerier should work, but the SQL is a bit more complex:
Select d1.DEMAND1, d1.PATTERN1
, (Select d2.FACTOR from DBF2 d2 where d2.PATTERN_id = d1.PATTERN1) as PAT1_FACTOR
, d1.DEMAND2, d1.PATTERN2
, (Select d2.FACTOR from DBF2 d2 where d2.PATTERN_id = d1.PATTERN2) as PAT2_FACTOR
etc.
From DBF1 d1
That should give you the right result.
erik_jan
Forum|alt.badge.img+26
  • August 15, 2017
etc.
From DBF1 d1
erik_jan
  • August 15, 2017
etc.
From DBF1 d1
And to get the 0 values instead of the Null values for non matching patterns you can follow the InlineQuerier by a NullAttributeMapper.
  • August 15, 2017
etc.
From DBF1  d1
Agree. You can accomplish the goal with a single SQL statement. This example assigns 0 to the default factor, although a bit more complex.
select
    a.ID,
    a.DEMAND1,
    a.PATTERN1,
    case
        when b.FACTOR is null then 0
        else b.FACTOR
    end as PAT1_FACTOR,
    a.DEMAND2,
    a.PATTERN2,
    case
        when c.FACTOR is null then 0
        else c.FACTOR
    end as PAT2_FACTOR,
    a.DEMAND3,
    a.PATTERN3,
    case
        when d.FACTOR is null then 0
        else d.FACTOR
    end as PAT3_FACTOR,
    a.DEMAND4,
    a.PATTERN4,
    case
        when e.FACTOR is null then 0
        else e.FACTOR
    end as PAT4_FACTOR,
    a.DEMAND5,
    a.PATTERN5,
    case
        when f.FACTOR is null then 0
        else f.FACTOR
    end as PAT5_FACTOR
from DBF1 as a
left outer join DBF2 as b on b.PATTERN_ID = a.PATTERN1
left outer join DBF2 as c on c.PATTERN_ID = a.PATTERN2
left outer join DBF2 as d on d.PATTERN_ID = a.PATTERN3
left outer join DBF2 as e on e.PATTERN_ID = a.PATTERN4
left outer join DBF2 as f on f.PATTERN_ID = a.PATTERN5
