Using HttpCaller with custom SSL client certificate - doesn't work !?
  • Mar 7, 2025 8:40 AM UTC
  • 116 views
lifalin2016
Forum|alt.badge.img+42
Apparently this feature was finally introduced 5 months ago, yay. I’ve been waiting for this for 5 years.
I’ve just tested it today, with a PKCS#12 certificate, and unfortunately it doesn’t work.
We’ve sofar been using our own C# service provider for this, and the certificate is used here on a daily basis with success. And I’ve verified the private key password.
Has anyone tried this feature (with PKCS#12) yet with success ?
Using 2024.2.3 (build 24825).
Cheers.
Best answer by lifalin2016
I reached out to the support team, and they found a solution. Thanks Debbie.
It seems that Workbench on Windows is built with two ways for handling (SSL) certificates, Windows own (Windows Secure Channel - schannel) and OpenSSL. The former fails while the latter works.
The trick is to add or edit an environment variable named CURL_SSL_BACKEND, and set it to openssl
This will tell Workbench to use the OpenSSL implementation, which works for me.
Hope this tidbit will help others that struggle with the same problem.
lifalin2016
  • Mar 14, 2025 1:19 PM UTC
