Using data from offset objects with condition
  • Oct 27, 2018 2:50 PM UTC
  • 83 views
I have a database with polygons. The data is three buffers (dounuts) around some points of interest with a unique location id. All donuts should get data from one or two of the neighbouring donuts.
This is the starting table (first four attributes are the starting ones):
idlocation_idbuffer_nrimportance_valueimportance_value_new110111022 (10+7+5)21012712 (7+5)3101355 (5)410212034 (20+11+3)510221114 (11+3)6102333 (3)7103123-etc
My table is sorted on location_id and buffer_nr. Basically:
  • for each buffer_nr=1 I want to create a new value based on the sum of all importance_value with the same location_id
  • for each buffer_nr=2 I want to create a new value based on the sum importance_value wwith buffer_id 2 and 3.
  • Oct 27, 2018 3:18 PM UTC
Reverse sorting. Continously put values in global values tagged with buffer number (global.buffer3, global.buffer2 and global.buffer1). Conditional additions based on buffer number. Could that work?
  • Oct 27, 2018 3:49 PM UTC
Once you have sorted the features by buffer_nr descending with the Sorter, you can calculate cumulative sum of the importance_value with the StatisticsCalculator. If necessary, use another Sorter to restore the original order of features.
  • Oct 28, 2018 7:19 PM UTC
This does not seem to solve the challenge of updating an attribute with data from offset objects.
  • Oct 29, 2018 4:04 AM UTC
This is the result from the workflow I posted above (just corrected a typo in the attribute name "importance_value_new"). Isn't this your desired result?
