using Choice user parameter in AttributeKeeper
  • June 30, 2023
  • 190 views
mzuer
Forum|alt.badge.img+5
Dear All,
I have the following setting : I've created a User parameter of type "choice" where the user can tick which attributes he wants to keep and send to the Writer (column1, column2, column3, etc.).
With the MultiChoiceParamSplitter followed by a ListExploder, I can get a table where the attribute "_choice_param_values" holds the attribute names the user has selected (e.g. column1, column3), but how can I use it then in the AttributeKeeper (or any other transformer that would do the job) ?
I've tried to pass the table as input with "_choice_param_values" as Attributes to Keep but it does not work at all...
Or maybe, from the outset, I didn't tackle the issue from the right angle and you have suggestions about how I could I achieve what I want in a totally different way around ?
Any ideas are welcome, as I've run out...
NB : I've seen the (seemlingly related) post below but it did not solve my issue.
Having trouble passing user parameter multi-attribute to transformers with attributes to select (safe.com)
Best answer by itsmatt
You can try and create the parameter directly from the transformer itself:
This works but you will need to take care because the schema gets completely removed in the process.
gazza
  • July 3, 2023
The attached workspace may give you some ideas, although it is about removing attributes rather than keeping them. It creates a regex string of attributes to remove and passes that to a BulkAttributeRemover.
itsmatt
Forum|alt.badge.img+48
  • July 4, 2023
