Using BulkAttributeRenamer to rename attribute names to only the first 10 characters.
  • Apr 11, 2019 9:52 PM UTC
  • 187 views
ngstoke
Hello,
I'm having issues when trying to get the BulkAttributeRenamer to perform the following:
I need trim all attribute names down to only 10 characters in length.
When I set the Parameters for Action: to Regular Expression Replace and use this regular expression:
^.{10}
I'm able to match all the first 10 characters, but I actually don't need to replace these, I just want to use the matches to become the new attribute name. Am I going about this the wrong way with a regular expression? Any help is greatly appreciated.
Example:
Old Attribute Name ----> AREA_IMP_TEAM
New Attribute Name ----> AREA_IMPL_
debbiatsafe
Forum|alt.badge.img+24
Hi @ngstoke
Have you seen this previous Q&A post? I would recommend trying the solution in @egomm's answer. I believe that should trim the attribute names to the first 10 characters using the BulkAttributeRenamer.
