Using attribute name in HTTPCaller Request URL
  • Jan 30, 2019 3:57 PM UTC
  • 108 views
I have an unconventional excel spreadsheet where the first column is a work order number and the subsequent columns are employee names. Below each employee name are the hours they spent on each work order. See below:
The goal is not only to use the value of an attribute column but also the attribute name (in this case the employee name) in a httpcaller without transposing/pivoting. So in theory the Request URL in a HTTPCaller would have the following format:
https://***BaseAddress***/addcost?data={"WorkOrderID":@Value(Work Order ID),"Employee":"AttributeName","Hours": AttributeValue}
I've yet found a function to extract the attribute name. The text editor only allows me to extract the value of the attribute. I'm unsure how to accomplish this.
Any recommendations is greatly appreciated.
  • Jan 30, 2019 4:14 PM UTC
You could look into maybe using the AttributeExploder (keep attributes = yes) and then filter away the feature where _attr_name = "Work Order ID". The URL might look something like
https://***BaseAddress***/addcost?data={"WorkOrderID":@Value(Work Order ID),"Employee":"@Value(_attr_name)","Hours": @Value(_attr_value)}
