Use tiler on a state boundary to build equal squares using map scale to calculate my width/height parameters for the Tiler
salvaleonrp
Forum|alt.badge.img+16
I have a state boundary and I want to use a map scale as a parameter to calculate the Tile width and Tile height (ground units) as attributes for the Tiler.
Given a coordinate system, how do I calculate that width and height of that bounding box at a scale of 1:100 using an Expression Evaluator? Then do it again for the next scales 1:500, 1:1000, etc.
Best answer by virtualcitymatt
BoundingBoxReplacer to get the box of the original unscaled state boundary > Scaler to scale the box to the arrpopriate scale > BoundsExtractor to get corners > ExpressionEvaluator to calculate diff bewtween max and mins.
virtualcitymatt
Forum|alt.badge.img+39
  • August 29, 2019
salvaleonrp
  • August 30, 2019
My premise was wrong but the solution is right. I need the relative spatial extent of the data and not really view extent. I can't have a map or display scale if I don't pick my map or display size. The number that I type in the scaler parameter became a number to make my tiles smaller or bigger.
I'm sharing my solution in case some else may have a need for it. The default Scaler parameter is set to 1 right now.
Thanks.
pyramid_tiler.fmwt
virtualcitymatt
Thanks.
pyramid_tiler.fmwt
Thanks for sharing!
