Use of Feauture Paths outside an XML Reader
  • Jun 22, 2016 8:06 AM UTC
  • 32 views
Is it possible to use Feature Paths without using an XML Reader? For instance when an xml structure is in an attribute as a string? I can write the contents to a file and start a workflow with the file as an XML Reader, but I would like that to do within one workflow.
Best answer by takashi
Hi @pimverver, yes you can use the Feature Paths in the XMLFragmenter transformer. Choose 'Attribute with XML document' as the XML Source Type parameter.
  • Jun 22, 2016 8:13 AM UTC
  • Jun 22, 2016 9:03 AM UTC
Very nice! Thank you @takashi
