use feature information in testfilter to check if its a roof
  • Sep 17, 2019 1:30 PM UTC
  • 57 views
hello,
i have 3 buildings i made from faces and i want to use the testfilter to check if the fme_vertex_normal_z property has a value of 1 and then make that a roof and if it's not 1 make it a wall
these are the features
this is the the testfilter
Best answer by gio
@richardkits1224
In your picture you can see those are measures.
So i assume you can use MeasureExtractor to get the values into attributes.
gio
Forum|alt.badge.img+15
  • Sep 17, 2019 1:36 PM UTC
@richardkits1224
@richardkits1224
thank you that worked
itay
Forum|alt.badge.img+19
  • Sep 17, 2019 2:28 PM UTC
I would use the PlanarityFilter for that job
