Use AttributeSplitter with a Carriage Return
  • February 16, 2013
  • 950 views
fmelizard
Forum|alt.badge.img+22
I am trying to split text features that contain a carriage return into two separate pieces of text so I can better control the spacing between the text lines.  I can use a StringSearcher to find the text using the \\r variable.  However, when I try to the use the \\r in the AtrributeSplitter, it will not split it into two separate list elements.  I am using FME2012.
  • February 17, 2013
In FME 2013, we can select special characters including carriage return on Advanced Text Editor when setting the parameter of AttributSplitter. I forgot whether there was such an editor in FME 2012...   Alternatively, how about trying a combination of StringReplacer and AttributeSplitter?  Replace \\r with \\n by StringReplacer (Use Regular Expression = yes), then split the text at \\n by AttributeSplitter.   Hope this helps.
kathyross
Participant
Forum|alt.badge.img+9
  • Participant
  • February 18, 2013
In FME2012, \\n is the newline character within the AttributeSplitter.
The reference is as follows:
http://fmepedia.safe.com/articles/Samples_and_Demos/AttributeSplitter
If such doesn't work, also refer to:
http://fmepedia.safe.com/AnswersQuestionDetail?id=906a0000000cb1hAAA
  • February 18, 2013
The newline character(s) may vary depending on the input data format and operating system. Unfortunately, it can be rather complicated sometimes, see http://en.wikipedia.org/wiki/Newline for a more complete discussion.
In FME 2012, the following may work in some cases:
  • Open the AttributeSplitter parameters
  • For "Delimiter or Format String", click the button and select "Open Editor..."
  • In the editor window, press the Enter key once (and nothing else) to insert a single newline
  • Click Ok twice
fmelizard
  • February 18, 2013
The option that worked was opening the Editor within the AttributeSplitter and then selecting New line as the String Type.
Neither the AttributeSplitter nor the StringReplacer would accept \\r as an input.
