URL with Text using HTML in Attribute Manager
  • Nov 29, 2022 11:57 PM UTC
  • 354 views
vxn43
Forum|alt.badge.img+20
Wondering how to create a hyperlink that will show the blue underlined text value in a field and when you hover mouse over the text you will be able to click on a url. My Writer is to file geodatabase. I have a single url that I want to associate with the text values in a field. Attached is what I have done so far using the AttributeManager Conditional Parameters.
I do not want the actual URL to appear in the field.
URL with Text Link
Best answer by redgeographics
You can create a <a> tag for a hyperlink like so:
<a href="your_url">Your link text</a>
However, that literal text will be written to your geodatabase, so whichever application you use to work with the data needs to be able to interpret that.
Forum|alt.badge.img+63
