Urgent: Excel Writer issue using v2023.0.0.3
  • Jun 19, 2023 10:12 AM UTC
  • 240 views
sameer
Forum|alt.badge.img+23
Hello "Safers"
Migrated from latest 2022 build to 2023 2 days ago.
Noticed that some of my scheduled Automations failed and the issue is linked to the Excel Writer (The Writer itself or FeatureWriter)
These workspaces have, obviously, worked prior to the upgrade for some time now.
The Server log outputs the following for one of the workspace (Same error for the other workspace):
59 2023-6-19 10:01:01 | Emptying factory pipeline
60 2023-6-19 10:01:02 | OneDriveConnector: Downloading file "MO-Emails.json" to specified folder "E:\\FME Workbench\\Planning Support\\LetterOfRepresentations\\JSON-Input"
61 2023-6-19 10:01:02 | Creating reader for format: JSON (JavaScript Object Notation)
62 2023-6-19 10:01:02 | Trying to find a DYNAMIC plugin for reader named `JSON'
63 2023-6-19 10:01:02 | Loaded module 'JSON' from file 'E:\\FMEFlow\\Server\\fme\\plugins/JSON.dll'
64 2023-6-19 10:01:02 | FME API version of module 'JSON' matches current internal version (4.0 20230418)
65 2023-6-19 10:01:02 | Performing query against JSON dataset `E:\\FME Workbench\\Planning Support\\LetterOfRepresentations\\JSON-Input\\MO-Emails.json'
66 2023-6-19 10:01:02 | Creating reader for format: JSON (JavaScript Object Notation)
67 2023-6-19 10:01:02 | Trying to find a DYNAMIC plugin for reader named `JSON'
68 2023-6-19 10:01:02 | Opening the JSON reader with source dataset 'E:\\FME Workbench\\Planning Support\\LetterOfRepresentations\\JSON-Input\\MO-Emails.json'
69 2023-6-19 10:01:02 | Creating writer for format:
70 2023-6-19 10:01:02 | Using MultiWriter with keyword `FeatureWriter' to output data (ID_ATTRIBUTE is `multi_writer_id')
71 2023-6-19 10:01:02 | Creating writer for format: Microsoft Excel
72 2023-6-19 10:01:02 | Trying to find a DYNAMIC plugin for writer named `XLSXW'
73 2023-6-19 10:01:02 | Loaded module 'XLSXW' from file 'E:\\FMEFlow\\Server\\fme\\plugins/xlsx.dll'
74 2023-6-19 10:01:02 | FME API version of module 'xlsx' matches current internal version (4.0 20230418)
75 2023-6-19 10:01:02 | FME Configuration: No destination coordinate system set
76 2023-6-19 10:01:02 | Writer `FeatureWriter_0' of type `XLSXW' using group definition keyword `FeatureWriter_0_DEF'
77 2023-6-19 10:01:02 | Excel Writer: Use Attribute Names As Column Positions is set to 'no' for sheet 'Output' in dataset '\\\\...\\shared\\Planning\\Letters of Representation\\Letters_Of_Rep.xlsx'
78 2023-6-19 10:01:02 | Excel Writer: Deleted existing destination file '\\\\...\\shared\\Planning\\Letters of Representation\\Letters_Of_Rep.xlsx'
79 2023-6-19 10:01:02 | Excel Writer: Opening dataset '\\\\...\\shared\\Planning\\Letters of Representation\\Letters_Of_Rep.xlsx'...
80 2023-6-19 10:01:02 | Excel Writer: Failed to open the dataset '\\\\...\\shared\\Planning\\Letters of Representation\\Letters_Of_Rep.xlsx'. Error message was 'No such file or directory.'
81 2023-6-19 10:01:02 | XLSXW writer: An error has occurred. Check the logfile above for details
82 2023-6-19 10:01:02 | Closing the JSON reader
83 2023-6-19 10:01:02 | PythonFactory output feature was rejected downstream. Check the logfile above for details
84 2023-6-19 10:01:02 | An error has occurred. Check the logfile above for details
85 2023-6-19 10:01:02 | Error encountered while calling method `input'
86 2023-6-19 10:01:02 | OneDriveConnector_CALLER (PythonFactory): PythonFactory failed to process feature
87 2023-6-19 10:01:02 | Excel Writer: Saving changes to dataset '\\\\...\\shared\\Planning\\Letters of Representation\\Letters_Of_Rep.xlsx'
88 2023-6-19 10:01:02 | Excel Writer: Workbook contains 5 fonts and 21 cell formats after writing
89 2023-6-19 10:01:02 | Excel Writer: Dataset '\\\\...\\shared\\Planning\\Letters of Representation\\Letters_Of_Rep.xlsx' contains no data and is therefore not a valid Excel file. No file will be created
90 2023-6-19 10:01:02 | XLSXW writer: An error has occurred. Check the logfile above for details
91 2023-6-19 10:01:02 | Translation FAILED with 8 error(s) and 0 warning(s) (0 feature(s) output)
92 2023-6-19 10:01:02 | FME Session Duration: 1.8 seconds. (CPU: 0.3s user, 0.4s system)
93 2023-6-19 10:01:02 | END - ProcessID: 11224, peak process memory usage: 106188 kB, current process memory usage: 86616 kB
The Excel Writer is set to "Overwrite". It is deleting the file then not finding it again I think. Same rule applied to the worksheet.
Workspace:
imageFeatureWriter setting:
Best answer by kailinatsafe
The following screenshot shows that the workspace worked then failed which is somewhat confusing.
It is scheduled to run every hour between 08:00 and 16:00 / Mon-Fri
If I set Overwrite to "No" then it seems to work.
Hello @sameer​, thanks for posting! Unfortunately this is a known issue in FME Form (FMEENGINE-78316). To workaround this issue for the time being, is it possible to disable 'overwrite existing file' on the Excel Writer, writing a new spreadsheet each time? Otherwise, you can roll back to FME 2022.2.5, where the issue was not present (Downloads Page). I'll make sure to update this thread when a fix is available! Happy to help, Kailin.
sameer
  • Jun 19, 2023 10:15 AM UTC
kailinatsafe
Forum|alt.badge.img+24
  • Jun 19, 2023 3:17 PM UTC
sameer
  • Jun 20, 2023 12:11 PM UTC
Hello @kailinatsafe​ , thanks for the update.
That's what I've done in the end as well. Set Overwrite to No. In some cases I had to remove / add the Writer and reconfigure.
PS: On a different note but still related, the hyperlink "Workarounds to Known Issues" points to "https://community.safe.com/s/article/Known-Issues-in-FME-2022-x" and not 2023.
I replaced the "2" in 2022 within the URL to "3" and ended in the 2023 page but did not find FMEENGINE-78316.
Do you mind looking into this please? That page is an excellent point of reference overall.
kailinatsafe
Hello @sameer​, I'm glad you were able to workaround it for the time being! I've just updated the Known Issues in FME 2022-x article to include FMENGINE-78316, but here is the 2023-x article as well! Best, Kailin.
