upgrade transformer FMEServerJobSubmitter to version some outputs disappears
  • Apr 17, 2018 1:02 AM UTC
  • 68 views
rudy_v
Hi All,
I have upgrade my FMEServerJobSubmitter to version 3 from 2, and now some output parameters has disappeared.- i have been using the number of features output, time start and time finish
version 2 below
after upgrade, it is no longer available, and make the attribute manager fail
  • Apr 17, 2018 7:35 AM UTC
Actually, the previous versions of the FMEServerJobSubmitter had a slightly broken logic, where e.g. the _numFeaturesOutput attribute would be exposed even when Wait for jobs to complete = No, which didn't make any sense.
Now, the attributes are dynamic according to how you set the "Wait for job" parameter.
Wait for jobs to complete = Yes
Based on the fact that your output port is called "Submitted" and not "Succeeded", I'm guessing Wait for jobs to complete = No in your workspace. If you change it around, you should get back the missing attributes.
rudy_v
  • Apr 17, 2018 11:52 PM UTC
@david_r - thanks for the update - but you don't get the succeeded / failed if
wait for job to complete is a published parameter
  • Apr 18, 2018 7:14 AM UTC
Ah, that's an interesting edge case, thanks for pointing that out.
It kinda makes sense, however, since parameters aren't resolved before you actually execute the workspace. But still, I can see how that's annoying in this case.
