updating xml -- figuring out if a node is missing and needs to be added or there and update with new content
  • September 27, 2017
  • 10 replies
  • 293 views
tnarladni
Forum|alt.badge.img+24
I am attempting to update an xml attribute (geodb_metadata_file) for multiple features. Some features have more xml content than others. I need to figure out which nodes are missing and will add content and which nodes are there and need to update content. There are about 7 nodes that I am testing but could be more so I need a generic way to test. a "for each" loop through a list of nodes to test and pathing the result into either update or add is my pseudo solution, but I don't know how to do that in a workspace except to have multiple testers which feels wrong.
Please help!
danilo_fme
Forum|alt.badge.img+57
Hi @tnarladni,
This post that you created is not good for you?
XML
Thanks,
Danilo
tnarladni
Hi @tnarladni,
XML
Thanks,
Danilo
the problem is that I am trying to expand upon that script and putting in multiple testers, 7 testers for the 7 nodes and 14 xmlUpdaters (2 for each nodes depending on if I'm adding or updating) works but is very messy. I'm trying to find a more efficient way to do it.
danilo_fme
About the transformer 7 Tester you can to replace with a simple transformer TestFilter.
tnarladni
Hi @tnarladni,
XML
Thanks,
Danilo
except the nodes are independent of each other and multiple nodes could be missing so a testFilter will not work. I would have to test for each node independently. with the testFilter, once features go out one port, it will not go out the other ports.
  • September 28, 2017
Hi @tnarladni, a possible way is to run an XQuery expression to once delete all the target nodes and then reinsert the nodes with new values.
For example, assume the original XML document was
<root>
    <parent>
        <a>xxx</a>
        <c>zzz</c>
    </parent>
</root>
the XMLXQueryUpdater with this XQuery expression
(: Once delete all the target nodes. :)
let $nodes := (//parent/a, //parent/b, //parent/c)
for $x in $nodes return delete node $x,
(: Reinsert the nodes with new values. :)
insert nodes (
    <a>foo</a>,
    <b>bar</b>,
    <c>foobar</c>
) as first into //parent
updates the original XML to this one.
<root>
    <parent>
        <a>foo</a>
        <b>bar</b>
        <c>foobar</c>
    </parent>
</root>
There should be uncountable variations depending on the actual XML schema and requirements.
<root>
    <parent>
        <a>xxx</a>
        <c>zzz</c>
    </parent>
</root>
insert nodes (
    <a>foo</a>,
    <b>bar</b>,
    <c>foobar</c>
<root>
    <parent>
        <a>foo</a>
        <b>bar</b>
        <c>foobar</c>
    </parent>
</root>
Of course you can assign the values of feature attributes to the nodes.
insert nodes (
    <a>{fme:get-attribute("a")}</a>,
    <b>{fme:get-attribute("b")}</b>,
    <c>{fme:get-attribute("c")}</c>
tnarladni
<root>
    <parent>
        <a>xxx</a>
        <c>zzz</c>
    </parent>
</root>
insert nodes (
    <a>foo</a>,
    <b>bar</b>,
    <c>foobar</c>
<root>
    <parent>
        <a>foo</a>
        <b>bar</b>
        <c>foobar</c>
    </parent>
</root>
xQuery is so powerful, and I don't know how to use it! Once again @takashi, you have saved my bacon. Thank you!
<root>
    <parent>
        <a>xxx</a>
        <c>zzz</c>
    </parent>
</root>
insert nodes (
    <a>foo</a>,
    <b>bar</b>,
    <c>foobar</c>
<root>
    <parent>
        <a>foo</a>
        <b>bar</b>
        <c>foobar</c>
    </parent>
</root>
Good to hear it helps you. Besides, this simple syntax is also available to delete multiple nodes at once.
delete nodes (
    //parent/a,
    //parent/b,
    //parent/c
insert nodes (
tnarladni
  • October 5, 2017
<root>
    <parent>
        <a>xxx</a>
        <c>zzz</c>
    </parent>
</root>
insert nodes (
    <a>foo</a>,
    <b>bar</b>,
    <c>foobar</c>
<root>
    <parent>
        <a>foo</a>
        <b>bar</b>
        <c>foobar</c>
    </parent>
</root>
@takashi so when I run this on production, I get error messages that the //parent does not exist. and it's true that some of the xml documents will not have that //parent element. After much trial and errors I figured out (yah me!) the code to see if that //parent element exists. The problem is, the simple script works:
But as part of the delete/insert script, it fails:
Please, could you help? TIA
  • October 8, 2017
<root>
    <parent>
        <a>xxx</a>
        <c>zzz</c>
    </parent>
</root>
insert nodes (
    <a>foo</a>,
    <b>bar</b>,
    <c>foobar</c>
<root>
    <parent>
        <a>foo</a>
        <b>bar</b>
        <c>foobar</c>
    </parent>
</root>
If there could be a case where the parent node doesn't exist, and you need to insert a parent node with a full set of child nodes in that case, this approach might help you.
(: Create a new parent node with a full set of child nodes :)
let $p :=
<parent>
</parent>
return
if (fn:exists(//parent)) then
    (: Replace the existing parent node with the new parent node :)
    replace node //parent with $p
else
    (: Insert the new parent node into the grandparent node :)
    insert node $p as first into //root
