Updatedetector -- Seperate output form geometry and attribute changes
  • May 14, 2018 3:21 PM UTC
  • 79 views
Hi all,
I want to compare line data for change detection in attributes and in geometry. I prefer the UpdateDetector transformer but in outputs I do not get separated the changes in attributes and the changes in geometry. These are mixed in the output. For example, in the Insert output, I’ ve got insert new data and attribute changes. Do you have any idea how can I do that?
Thanks a lot for your time and help
Noni
Best answer by dionymarko
Thank u for answering me Erik. But how can I define that this is only for attributes or only for geometry?
erik_jan
Forum|alt.badge.img+26
  • May 14, 2018 4:51 PM UTC
The easiest way would probably be to use two UpdateDetector transformers in parallel
One to check attributes only, One to check geometry only.
  • May 14, 2018 5:59 PM UTC
jdh
Forum|alt.badge.img+41
  • May 14, 2018 6:07 PM UTC
For the attributes only set Match Geometry to None.
For the geometry only, you need to edit the custom transformer to make the MATCHATTRS parameter optional.
