Update values in xml with conditionals
  • Jun 20, 2018 1:46 PM UTC
  • 114 views
djmcdermott
Forum|alt.badge.img+7
Hi FME'ers,
I am trying to update values in an XML documents but these values are conditional. For example:
IF <MethodCode> like 'FF%' THEN <MethodCode> = 'PM'
and
IF <MethodCode> = 'FF12' AND '<ItemDesc> = 'Basket' THEN <ItemDesc> = 'Wicker Basket'. ELSEIF <MethodCode> = 'FF10' AND '<ItemDesc> = 'Basket' THEN <ItemDesc> = 'Laundry Basket'
I think XQUERY will solve my issue but I don't have time to learn a new query language.
Many thanks,
David
  • Jun 20, 2018 4:10 PM UTC
Yes, you can do that with an XQuery expression (XMLXQueryUpdater). I think the following example contains every syntax you have to learn for the present.
Source XML
<items>
    <item>
        <code>X1</code>
        <desc>aaa</desc>
    </item>
    <item>
        <code>X2</code>
        <desc>aaa</desc>
    </item>
    <item>
        <code>X2</code>
        <desc>bbb</desc>
    </item>
    <item>
        <code>Z3</code>
        <desc>aaa</desc>
    </item>
</items>
XQuery Expression (assume that an attribute storing the source XML is set to the XML Attribute parameter in the XMLXQueryUpdater)
for $item in //item
let $code := data($item/code)
let $desc := data($item/desc)
return
if (matches($code, '^X.*')) then (
    replace value of node $item/code with 'KK',
    if ($code = 'X1' and $desc = 'aaa') then
        replace value of node $item/desc with 'foo aaa'
    else if ($code ='X2' and $desc = 'aaa') then
        replace value of node $item/desc with 'bar aaa'
    else ()
else ()
Result
<items>
    <item>
        <code>KK</code>
        <desc>foo aaa</desc>
    </item>
    <item>
        <code>KK</code>
        <desc>bar aaa</desc>
    </item>
    <item>
        <code>KK</code>
        <desc>bbb</desc>
    </item>
    <item>
        <code>Z3</code>
        <desc>aaa</desc>
    </item>
</items>
If you need more specific solution, please post a small (but valid) sample XML and your desired result corresponding to the sample.
djmcdermott
  • Jun 20, 2018 5:28 PM UTC
Source XML
<items>
    <item>
        <code>X1</code>
        <desc>aaa</desc>
    </item>
    <item>
        <code>X2</code>
        <desc>aaa</desc>
    </item>
    <item>
        <code>X2</code>
        <desc>bbb</desc>
    </item>
    <item>
        <code>Z3</code>
        <desc>aaa</desc>
    </item>
</items>
for $item in //item
return
    else ()
else ()
Result
<items>
    <item>
        <code>KK</code>
    </item>
    <item>
        <code>KK</code>
    </item>
    <item>
        <code>KK</code>
        <desc>bbb</desc>
    </item>
    <item>
        <code>Z3</code>
        <desc>aaa</desc>
    </item>
</items>
Hi @takashi. Thank you for your response. I said to my colleagues after I posted that you’d be the one with the solution.
In was very close with my own attempt. Sorry to throw this in but the xml has a namespace. Do I have to declare it and therefore prefix the nodes with //x: (for example)
  • Jun 20, 2018 9:33 PM UTC
Source XML
<items>
    <item>
        <code>X1</code>
        <desc>aaa</desc>
    </item>
    <item>
        <code>X2</code>
        <desc>aaa</desc>
    </item>
    <item>
        <code>X2</code>
        <desc>bbb</desc>
    </item>
    <item>
        <code>Z3</code>
        <desc>aaa</desc>
    </item>
</items>
for $item in //item
return
    else ()
else ()
Result
<items>
    <item>
        <code>KK</code>
    </item>
    <item>
        <code>KK</code>
    </item>
    <item>
        <code>KK</code>
        <desc>bbb</desc>
    </item>
    <item>
        <code>Z3</code>
        <desc>aaa</desc>
    </item>
</items>
Yes, you have to declare namespaces at the top of the expressions if the source XML has elements belonging to a namespace. General syntax is:
declare namespace <prefix> = "<namespace name>";
Note that a declare statement should end with a semicolon, unlike expression body.
Then, in the expression body, qualify all element names belonging to the namespace by the prefix.
