Update phone numbers based on Excel file (RegEx, AttributeManager or FeatureMerger?)
  • Feb 20, 2018 1:35 PM UTC
  • 115 views
Hi all,
I have to bulk update a whole bunch of phone numbers.
The current format is ten digits, starting with a 0. I need to convert these numbers to area code + local number.
The area code is either three or four digits followed by a dash (-).
The area codes are stored in enclosed file "PhoneUpdating"
The input and output phone numbers are in "PhoneOutput"
What I'd like FME to do:
When the first three or four digits in the "Phone" column match with the thee or four digits found in AreaCode: then replace these with the data found in AreaCodeUpdated. (output examples in green)
Example files:
Thanks again,
Ed
Best answer by takashi
Hi @edhere, hope this works as expected.
String expression in the StringConcatenator
@Value(AreaCode)-@Substring(@Value(Phone),@StringLength(@Value(AreaCode)))
  • Feb 20, 2018 2:13 PM UTC
  • Feb 21, 2018 12:36 PM UTC
Thanks @takashi , it works nicely!
It seems I need to add a two digit (06) area code as well.
Should I add another tester at the beginning that creates a separate flow for string length 2 and direct that to another FeatureMerger that joins @Left(@Value(Phone),2) ?
Thanks,
Ed
  • Feb 21, 2018 1:08 PM UTC
Yes. Separate the AreaCode records into three streams for 4, 3, and 2 digits, and then add a FeatureMerger as you mentioned.
If you feel it's too cluttered, the InlineQuerier could be an alternative.
SQL
select B.AreaCode, B.AreaCode||'-'||substr(A.Phone,5) as PhoneOutput
from A inner join B on B.AreaCode = substr(A.Phone,1,4)
union all
select B.AreaCode, B.AreaCode||'-'||substr(A.Phone,4)
from A inner join B on B.AreaCode = substr(A.Phone,1,3)
union all
select B.AreaCode, B.AreaCode||'-'||substr(A.Phone,3)
from A inner join B on B.AreaCode = substr(A.Phone,1,2)
